#1 2019-02-08 20:54:41
RodrigoDeNadai
Dimming Problem
Hello Shanin
First of all, congratulations to the work you have been doing over the years. It is an amazing software.
I've been using the latest beta version (build 1984) and I have some questions about dimming.
My projector is an Optoma HD20 with 600h lamp usage and I've set the brightness on the projector to 0.
As you can see in the images bellow, using Checkerboard Dimming Type, 100% Dimming Amount Percentage and 3 as Wall Around Dimming, some straight lines appear in white when I set the contrast to maximum and in black when I set to 25%.
Dimming100 Checkerboard Wall3
Also using Checkerboard and wall as 3, I set the Dimming Ammount Percentage to 35% and the problem persists as you can see.
Dimming35 Checkerboard Wall3
The problem is solved when i use Homogeneous as Dimming Type, as you can see.
 Dimming35 Homogeneous Wall3
Do you know what is happening?
Whats the real difference between homogeneous and checkerboard?
#2 2019-02-08 21:21:22
Re: Dimming Problem
Is the image on dashboard is correct?
#3 2019-02-09 12:53:13
RodrigoDeNadai
Re: Dimming Problem
Hi Shahin,
The dashboard image is correct.
#4 2019-02-10 20:35:28
Re: Dimming Problem
I guess wrong HDMI output settings causing this. Also projector picture processing settings could cause it.
#5 2019-02-12 21:52:48
RodrigoDeNadai
Re: Dimming Problem
Thank you Shahin,
my RPi resolution was wrongly configured.
