#1 2016-08-20 07:51:32
Derek
Another operation system
While I use this awesome NANODLP solution, there was some troubles in operating.
When I doing my job as a big size, the loading time is too late!
So, I want to use nanodlp on another OS such as Windows or Linux ported normal PC.
There is notification on FAQ page that nanodlp supports Windows or another OS however I couldn't find any links or files for compile.
Does anyone have tried this way before?
#2 2016-08-20 08:45:53
Re: Another operation system
If the speed issue is only related to STL file slicing. I think converting STL to SLC on your PC and upload SLC to nanodlp will yield better results without losing any advanced image processing feature.
You can try windows and linux version from here. https://github.com/nanodlp/ui
You need to add your own syscalls to handle image display. You will have better chance with linux version as it is almost same as one used on Raspberry pi.
