#1 2017-06-13 21:01:29
macdarren
Plate Add Exit....
While I like how "add plate with support" now passes through the configuration dialog, I think probably  choosing EXIT from the plate setup should probably not pass through this dialog but return to the Plate page directly...as you are not probably going to now add a plate...might be wrong here and you will instead add as if if you were just not using support but it seems odd to choose exit then forced to submit you could add an exit to the simple add plate which seems like it might be a good idea but clicking exit twice seems odd too.
#2 2017-06-14 18:12:00
Re: Plate Add Exit....
Fixed, thank you.
