#1 2018-08-07 16:29:34
AntunesS
Led Turn on/off
Hello all,
I would like to control the UV LEDs by controlling a relay with fan pin d9 of the Ramps board.
When I turn on the "fan" by command M106 nothing happens and the output voltage from d9 is 0.
Someone knows what's going on?
Thank you
#2 2018-08-07 22:48:17
bigfilsing
Re: Led Turn on/off
try M106 S255
the "s" is the signal level  255 = 100%  ....127 = 50% and so on
to switch off you can use M107 or M106 S0
