#1 2019-08-20 20:00:55
amac26
Python Guide
I have worked in python in the past, and I was wondering if anyone had some kind of guide to writing python script specifically for NanoDLP? I understand that python can be used to do calculations and output gcode, but I am unsure where to start. Any tips would be greatly appreciated! Thank you!
#2 2019-08-22 05:14:17
Re: Python Guide
There are two ways of modifying values on nanodlp during printing. [[Net ]] and [[Exec ]] keywords check out on-screen help for code boxes.
NanoDLP could call external program or communicate through port and put result inside gcode box for further calculation and etc.
#3 2019-08-23 19:20:36
amac26
Re: Python Guide
Shahin,
Thank you for your response! I have a few more questions regarding starting the code.
1. I understand the [[Exec]] command requires a python file name. Does this file have to be saved in a specific location? I am currently using a Raspberry Pi 3 b+, so would I have to save the python file on the SD card?
2. Is there any chance you have a simple example of a python code that can be read by NanoDLP? I am unsure how to request variables from NanoDLP in Python, as my knowledge of Python is very limited.
Any help you could offer would be greatly appreciated! Thanks again!
#4 2019-08-24 17:22:03
Re: Python Guide
1. No not important just put correct path: python interpreter + py file
