#1 2018-09-21 02:31:57
TomTuko
Unable to login to nanodlp using putty
Hi. I'm trying to setup my Raspberry pi 3b+ for use with a D7.
I'm making a bit of progress but I can't get the wireless to connect. The log file shows.
    Connection Error exit status 255 Successfully initialized wpa_supplicant
ioctl[SIOCSIWENCODEEXT]: Invalid argument
ctrl_iface exists and seems to be in use - cannot override it
Delete '/var/run/wpa_supplicant/wlan0' manually if it is not used anymore
Failed to initialize control interface '/var/run/wpa_supplicant'.
You may have another wpa_supplicant process already running or the file was
left by an unclean termination of wpa_supplicant in which case you will need
to manually remove this file before starting wpa_supplicant again.
So I'm trying to connect to the pi using putty. When I connect it get the login prompt and enter "pi" as the user and then "nanodlp" as the password.
The password is rejected.
Any ideas?
#2 2018-09-21 03:19:16
bigfilsing
Re: Unable to login to nanodlp using putty
Try using the default password "raspberry"
#3 2018-09-21 05:05:35
TomTuko
thanks. that got it.
