#1 2018-10-19 07:30:14
color
"Serial port could not be activated"
I am building my second DLP printer and have troubles with comunication between RPi and Mega 2560 board. When turn power on and nanodlp load, the following error appear: "Serial port could not be activated not such file or directory"
The Mega 2560 is probably chinese clone, but I can compile and load sketches, and run some test like LED blinking. My VEML6070 UV sensor attached to the same board also run well and can read its monitoring. Any ideas how to solve this problem?
Here are the debug file in atachement
nanodlp.debug.-732792820.zip
#2 2018-10-19 08:55:16
bigfilsing
Re: "Serial port could not be activated"
you might need to check the correct USB port is allocated in Nano DLP!  Heres a link identifying the section in Nano DLP setup  and the help file explaining how to go about finding the correct port
https://youtu.be/Laq8eovno9U?t=19
Good luck
#3 2018-10-19 09:06:52
color
Thanks bigfilsing,
The problem is resolved, I found the right settings for the USB port.
#4 2018-10-19 11:28:57
color
Ok, I figured out the problem, but how to resreve the virtual COM port? Everytime after restarting nanodlp, the address is diferent - USB0 or USB1, etc.
#5 2018-10-19 14:24:32
bigfilsing
i don think its a "virtual comm port" its the actual physical USB port on the Raspi thats communicating with your control board.
Dont forget when you make any changes on the setup page you have to scroll down and click "submit" !!
#6 2018-10-19 14:38:46
color
Yes, you are right, it's actual USB port. When I start nanodlp in setup page I set the USB1 if this is the actual port and then save this settings. Everything is OK, the RAMPS respond. But if I shut down the system and then start again, the USB adrres is diferent, for example USB0, and I have to set it manualy again.
#7 2018-10-19 15:24:02
colgeocol
color
Use this:
# suggested file name: /etc/rules.d/69_usbdevices.rules
KERNELS=="1-1.2", SUBSYSTEMS=="usb", SYMLINK+="usb_ul"
KERNELS=="1-1.3", SUBSYSTEMS=="usb", SYMLINK+="usb_ll"
KERNELS=="1-1.4", SUBSYSTEMS=="usb", SYMLINK+="usb_ur"
KERNELS=="1-1.5", SUBSYSTEMS=="usb", SYMLINK+="usb_lr"
#8 2018-10-20 15:11:56
color
Thanks, I have made a fresh nanodlp instalation and for now everything works good.
