nanoDLP's gcode design goal is to provide both synchronized movement and position recovery after crashes.
Both zero level at bottom and and at top supported but as RAMPS boards' zero point is at the bottom our sample will concentrate on that.
RAMPS with Marlin/Grbl patched firmwares
Start of Print
G90 ; Put positioning in absolute mode
G28 ; Homing
[[WaitForDoneMessage]] ; Wait until movement completed, require firmwares to patched for Z_move_comp, if you do not want to use patched firmware you can use [[Delay n.n]] instead
[[PositionSet 0]] ; Set current position on nanodlp so it could be recovered in case of failureBefore Layer
G1 Z[[LayerPosition]] ; Move to layer position
[[WaitForDoneMessage]] ; Wait for the movement finished
[[PositionSet [[LayerPosition]]]] ; Save layer position as the current positionAfter Layer
G1 Z{[[LayerPosition]]+[[ZLiftDistance]]} ; Lift to wait position
[[PositionChange [[ZLiftDistance]]]] ; Again update positionResume Print
G92 Z[[CurrentPosition]] Y0 X0 ; System crashed so we need to recover current position from nanodlp and set it on RAMP
...Offline
hi shanin, do you know if with 1322 nanodlp version, we can do what i describe below? (using botton-up printer b9c yellow resin, arduino uno ramps)
number of burn layers: 3
layer 1: cure for 100 sec + wait for 20 sec NO LIFTING after this + cure another 50 sec + wait 2 sec + lift 8 mm
layer 2: cure for 100 sec + wait for 20 sec NO LIFTING after this + cure another 30 sec + wait 2 sec + lift 4 mm
layer 3: cure for 100 sec + wait for 20 sec NO LIFTING after this + cure another 25 sec + wait 2 sec + lift 4 mm
normal layers: dinamic cure 30 sec for first 20 layers and 25 for rest of them lift 5 mm after each layer
I want to do this cause im having huge problems in adherence, using Aluminium, metacrilate and no results.
You should use dynamic lifting and dynamic cure time to do what you have described above.
If you have not done, anodize your platform. Also make sure it is in full contact with tank surface and completely parallel to it for the first layer.
I cant connect with custome GRBL and board on Adruino Uno R3, i see G code is same but have some small difference G Code to control title.
Can i patch this GRBL to work with NAnoDlp?
There is couple of patched GRBL out there but majority of are using Marlin. So if you can first try marlin.
Hello shanin,
My printer motor connect step dir to RPi board direct.
How to place command on Before Layer,After Layer ext... for move z axis to print?
You do not need to fill gcode boxes if you are using direct control as it should work out of box.
