#1 2018-12-23 13:25:14
DrNK
SLASH 3d printer. Is it possible to switch to NanoDLP?
Interesting
#2 2019-02-09 21:55:38
DrNK
Re: SLASH 3d printer. Is it possible to switch to NanoDLP?
up
#3 2019-02-10 20:32:42
Does it use RAMPS?
#4 2019-02-11 17:03:41
sandeep
may be yes.SLASH 3D based on raspberry Pi
#5 2019-02-11 21:02:38
So you should not have any problem moving to nanodlp. Just need to know gcode being used to control LED and other hardware features on your printer.
#6 2019-02-11 22:07:53
DrNK
What if we switch to  NanoDLP Shield v1.1 ?
US $12.52  25% Off | NanoDLP Shield V1.1 Expansion Board With DRV8825 Controled MOS For Raspberry Pi 3B And NanoDLP's Light-cured 3D Printers
https://s.click.aliexpress.com/e/c7gyvhHo
Printer has Nema 23 like stepping motor, liquid cooling circle to cool LCD and LED array.
I'd like to switch to 4k 8,9' screen from 2k
#7 2019-02-11 22:12:33
DrNK
#8 2019-02-12 19:19:04
Movements would not be very smooth. It is also possible.
#9 2019-02-13 07:20:01
oliveenchine
This looks very similar to Banana Pi M2 or NanoPi A 64. unmounting the 4 screws will give you (us) the answer smile
#10 2019-02-13 07:24:34
DrNK
I need precise and trueness movements. So, there is no problem for me to replace this board to Raspberry PI3. What else do I need to drive Stepping motor, liquid cooling motor?
#11 2019-02-13 20:47:18
The most probably your machine is already have RAMPS and motor driver with passive cooling, so you only need to use rpi instead of bannana pi (olivier guess) or even load nanodlp on this board directly.
Time consuming part will be translation of settings from your correct program to nanodlp
