Hi I'm trying to install the windows version (I just want to use this as a slicer) but I'm getting this error after downloading and extracting the files
2018/12/27 16:48:37.697102 {"Layer":"0","module":"Hardware","level":"Notice","msg":"Initializing build # 1936 - generic"}
2018/12/27 16:48:37.697102 {"Layer":"0","module":"SLAVE","level":"Error","msg":"Serial port could not be activated The system cannot find the path specified."}
2018/12/27 16:48:37.698097 {"Layer":"0","module":"Terminal","level":"Notice","msg":"Terminal Reader Activated"}
⇨ http server started on [::]:8080
How can I fix this?
Thanks a lot.
You have run it correctly. Just open it by typing http://127.0.0.1:8080 on your browser
Hi is there a way to extract the layers as image files?
You can find them as image files on folder public/plates/...
It was running okay a couple of days ago. I'm getting this error today
Access Error: 404 -- Not Found
Cannot locate document: /
Have you done anything to the extracted files?
Looks like static files moved / removed.
No I have not. I also redownloaded the files and extracted and same thing happened.
Provide screenshots from the error dialog
What's the url you are trying to open? Error is not generated by nanodlp
works on my home pc but not my laptop
I got the error above on my laptop
Something else responding to your request. Try change port editing db/machine.json
HI Shahin.I have the same problem with him.
"Access Error: 404 -- Not Found
Cannot locate document: /"
I have tried many times on win-64 or 32,but it didn't work.
Maybe it blocked by microsoft defender, if it is the case we need to raise issue to microsoft.
Charlie,
Change port see if the issue persists.
