#1 2018-12-12 05:16:27
Guennie
Problem with the Steppermotor
Raspberry has missing pulses (dropouts) at pin 16 (STEP pulses) during the Z-axis movement.
Result: Step losses when moving the Z-axis
These dropouts at the Raspberry output are clearly visible on the oscilloscope image.
Since these dropouts are directly visible at the output of the Raspberry, I suspect that this either comes from the operating system (e.g. interrupts) or the application.
Please help me.
Günther
#2 2018-12-12 05:49:53
Re: Problem with the Steppermotor
Lower the speed see if it makes any improvement. Due to nanodlp GC and non-realtime OS fast pulse generation is not possible.
#3 2018-12-12 19:28:26
Guennie
Thanks for this Info,
I have reduced the speeds, and now its working without missing pulses.....
are tested speed parameter sets available where I should move about ?
Best Regards
Günther
#4 2018-12-13 04:43:37
Default nanodlp settings is pretty reliable (max speed)
