I'm using a BeaglebBone Black Wireless. I install Debian linux on it and successfully installed NanoDLP on it. I'm facing an issue now with having the display overridden by NanoDLP display.
Currently, I get a terminal instead of NanoDLP images display.
Any idea how can I manage to fix this issue?
Correct framebuffer address on the setup page.
I've been doing some research concerning this task and I have already read a thread in the forum concerning framebuffer value
I have run the command
"fbset -v"
And received the following output
Linux Frame Buffer Device Configuration Version 2.1 (23/06/1999)
(C) Copyright 1995-1999 by Geert Uytterhoeven
Opening frame buffer device `/dev/fb0'
Using current video mode from `/dev/fb0'
mode "1280x1024"
geometry 1280 1024 1280 1024 16
timings 0 0 0 0 0 0 0
accel true
rgba 5/11,6/5,5/0,0/0
endmode
So as the message shows, I used "/dev/fb0" as the value for framebuffer but this also didn't work.
From NanoDLP side, the logs shows the following
Error 0 2018-07-16 09:52:33.569219 Framebuffer Custom channel implementation. 16 {0 5 0} 5 6 5
I'm not sure what this means, but I've also tried to do it on different displays/projectors which also failed
The command
ls -l /dev/fb*
only returns
crw-rw---- 1 root video 29, 0 Jul 16 09:48 /dev/fb0
As far as I'm understanding, the expected behavior after running NanoDLP (run.sh file), the terminal screen should turn black and only display images executed by NanoDLP, Am I right?
And If yes, any idea what the error returned means and how to fix it?
Are you sure display you are using is 1280*1024? If yes, change resolution on the setup page too.
