Hi guys
Just trying to build a machine using 7" LCD 1024x600 tconnected using HDMI and i cant get it to work in nanodlp windows version 32&64bit.
Link to the LCD
http://s.aliexpress.com/7nmA3QFF
What happens is the screen gets stuck afer pressing start display and when i press anything nanodlp crashes immediately.
I also tested the lcd and its working good in extended and duplicate mode.
I have already disabled the display communication type in setting's and im using ramps with patched firmware.
Can someone help me with that?
Still can get it to run
Looks like recent version of nanodlp for windows has issue. I am trying to fix it, please use it old version until I find what is wrong with windows version.
Thanks for the reply. I already tried 2 version (the latest and the one before it)
Can you suggest a specific version?
Please, download latest version see if it makes any difference.
Hi shahin
Just downloaded the latest version for Windows as you said. But still cant turn on the display.
What happens is when i click on start display the screen becomes white for 2-3 seconds and then the "nanodlp image viewer" minimize itself and the screen goes black and wont display anything even when i click on the minimized tab of the viewer it start to display the white screen for 2 sec and then black!!!
Any idea what that means?
I forgot to mention that 'nanodlp image viewer' tab shows as 'not responding when it appears after clicking on start display
Are you sure it is the latest version? As the `not responding ...` was the actual problem we have fixed on the latest version
100% sure
Just downloaded it 2 hours ago
try swapping
outputs on the video card
I had a problem on the xp
and check the card supports open GL it should be minimum 2.1
Already did and also try vga instead of HDMI but still no luck.
My first problem was nanodlp crashes each time i click on start display. But now in the new version there is no crashing. Only the problem mentioned above
Is there any open issue exists on windows version?
Hi shahin
From what i can see Everything works perfectly
Thank you
