#1 2017-05-09 12:51:26
caripen
Stop/Shutdown Physical GPIO
Hello, I'm trying to setup physical shutdown button. Which GPIO should I use? Also should I just short them with ground or with 3.3v VCC? do I need a resistor to limit the current?
Any help appreciated.
#2 2017-05-09 18:04:16
Re: Stop/Shutdown Physical GPIO
You can use any GPIO available in the list. Yes 3.3v. I am not sure about resistor I can ask and let you know.
#3 2017-05-10 09:34:43
caripen
It worked by shorting any selected pin from the list with 3.3v pin and 10k resistor.
Thanks for replying.
#4 2019-09-09 07:01:51
sinned6915
I am resurrecting this older thread instead of starting a new one....
What is the proper operation of the switch and what are the functions? Perhaps I am looking in the wrong place for info.
I have used this scheme on my other raspi's- is it the same? short press and long press?
http://scruss.com/blog/2017/10/21/combi … pberry-pi/
