#1 2016-07-12 04:29:25
Cuongcoco
Install nano dlp and config wifi
Hi admin,
I want use nanodlp with wifi connection, i already download nanodlp sd image card and burn it to sd card. When i install sd card to raspberry 3 , it boot up and show a black screen, i can type letter by keyboard but its not respon anything.
Please tell me when it show a black screen it already boot up and wait connect dlp or its fault.
I want use built in wifi of raspberry, how can i connect to wifi from a black screen to connect to network.
Thank you very much???
#2 2016-07-12 13:43:39
Re: Install nano dlp and config wifi
You should connect to the rpi through your browser. After installation rpi HDMI output could be used to manage nanodlp.
Checkout the installation document for the more details.
#3 2016-07-12 15:13:26
Cuongcoco
Thank you
I have a question about stepperunit
I use step 1.8 degree, connect to ratio 10:1 and conect to lead screw 6mm per turn, full step
I had edit in marlin firmware stepperunit is 333.33, in nanodlp i set motor step 1.8, microstep 1, leadscrew 6. But it not correct
The distant lift is smaller. Please help me
Thank you
#4 2016-07-12 19:11:44
It is good to have correct values for microstepping on nanodlp, but for the RAMPS, nanodlp just sends Gcodes in mm, so these settings on nanodlp side do not have any effect on amount of movement.
The issue is the most probably is settings on marlin side.
