Have ver 2227. After Updating to stable or beta version nothing happens and there is 2227 ver still. On current 2227 version Machine settings page is unavailable. What should I do?
Upgrade manually. there is issue related to 222* builds.
Sorry, could you please write the command for manual update?
Not sure if there is some dedicated "manual update" way, but the setup command variant is here: https://www.nanodlp.com/download
(wget https://www.nanodlp.com/nanodlp.tar.gz --no-check-certificate -O - | tar -C /home/pi -xz --warning=no-timestamp);cd /home/pi/printer;sudo ./setup.sh
I just don't see the "update" script in there, only the "setup"... So you need to be sure to not overwrite your already existing settings by different ones during setup...
Thanks a lot. My printer seller said that this command will clean all machine settings. He gave me instructions: on the raspberry memory SD card there is script to restore stock copy of nanodlp with all necessary settings. After that I could update it to the latest version.
I'm having the same problem.
VikluhaVaklay, would you be so kind to share the script to restore stock copy of nanodlp?
thank you very much
Hello! Om my printer script path is
/home/pi/install.sh
Your printer may have no such script.
Running installation would not replace settings.
Resin settings will be deleted, right?
