#1 2018-11-16 03:15:48
Statler
Wanhao D7 does not display any screen
Hello, I have successfully installed NanoDLP Build 1919 on a Raspberry Pi 3. After initial hickups with the z-axis and issues with the slowliness of response when using wifi, I am now stuck with the screen of the printer. On NanoDLP I can turn the shutter on and off, but it is impossible to project any kind of image (for example the calibration screen) to the screen.
EDIT: I connected the HDMI cable to another screen and it just showed the output which is also on the touchscreen. But not the calibration image
EDIT 2: calibration image came up on the computer screen, but not on the Wanhao screen....
Any ideas on what to do?
#2 2018-11-16 05:21:26
Re: Wanhao D7 does not display any screen
You probably need to adjust HDMI timing on config.txt
#3 2018-11-16 09:54:51
Statler
Thanks for pointing me into the right direction. I actually never adjusted the config.txt. It works fine, now! Thanks again!
#4 2019-05-22 02:26:28
econopotamus
Statler, can you tell the rest of us how you solved it? I'm facing the same no-display problem and my first few attempts at updating config.txt didn't fix it.
