#1 2017-01-15 11:56:21
djjohn
need help to make nanodlp turn projector on and of
so i have been building my own dlp printer from scratch and right now im trying to make nanodlp turn my projector on and off
it works when using usb to rs232 from my computer whith the commands:
1    OKOKOKOKOK\r    Power On
2    * 0 IR 001\r    Power On
3    * 0 IR 002\r    Power Off
but when i connect the usb to rs232 to nanodlp on my rpi3 it will nok work in the log it says it is turned on but it dosent
the projector i am using is acer x152H
does enybody have an solutin to this??
#2 2017-01-15 19:31:44
Re: need help to make nanodlp turn projector on and of
Hi John,
I am using similar projector with same command you mentioned without any issue.
Post your debug file.
#3 2017-01-15 21:39:26
djjohn
i am quite new to nanodlp.
where do i find the debug file
#4 2017-01-16 21:56:02
Setup page/Tools tab/ debug button.
#5 2017-01-27 08:37:54
djjohn
in the printer log i get this:
2017/01/25 11:49:32.393944 {"Layer":"1","module":"Terminal","level":"Notice","msg":"Terminal Reader Activated"}
⇛ http server started on :80
2017/01/25 11:49:32.484617 {"Layer":"1","module":"WIFI","level":"Warning","msg":"WIFI interface wlan0 detected"}
2017/01/25 11:49:32.525103 {"Layer":"1","module":"WIFI","level":"Warning","msg":"Connecting to TP-LINK_2723"}
2017/01/27 08:27:32.597687 {"Layer":"1","module":"Projector","level":"Notice","msg":"Projector on"}
2017/01/27 08:27:44.374391 {"Layer":"1","module":"Projector","level":"Notice","msg":"Projector on"}
2017/01/27 08:28:17.754700 {"Layer":"1","module":"Projector","level":"Notice","msg":"Projector on"}
2017/01/27 08:28:20.588145 {"Layer":"1","module":"Projector","level":"Notice","msg":"Projector on"}
2017/01/27 08:28:21.853213 {"Layer":"1","module":"Projector","level":"Notice","msg":"Projector off"}
2017/01/27 08:28:57.595066 {"Layer":"1","module":"Projector","level":"Notice","msg":"Projector on"}
and in the printer.men.log i get this:
2017-01-25 11:49:32.383936 {"Layer":"1","module":"Hardware","level":"Notice","msg":"Initializing build # 1331 - generic"}
2017-01-25 11:49:32.384794 {"Layer":"1","module":"SLAVE","level":"Error","msg":"Serial port could not be activated open /dev/ttyACM0: no such file or directory"}
2017-01-25 11:49:32.393866 {"Layer":"1","module":"Shutter","level":"Debug","msg":"Shutter Close"}
2017-01-25 11:49:32.394009 {"Layer":"1","module":"Hardware","level":"Debug","msg":"Stepper motor enabled"}
2017-01-25 11:49:32.394051 {"Layer":"1","module":"Terminal","level":"Notice","msg":"Terminal Reader Activated"}
2017-01-25 11:49:32.484704 {"Layer":"1","module":"WIFI","level":"Warning","msg":"WIFI interface wlan0 detected"}
2017-01-25 11:49:32.484919 {"Layer":"1","module":"WiFi","level":"Debug","msg":"Status Monitoring"}
2017-01-25 11:49:32.52519 {"Layer":"1","module":"WIFI","level":"Warning","msg":"Connecting to TP-LINK_2723"}
2017-01-25 11:49:42.490527 {"Layer":"1","module":"WiFi","level":"Debug","msg":"Connected to TP-LINK_2723"}
2017-01-27 08:27:24.833889 {"Layer":"1","module":"Hardware","level":"Debug","msg":"Stepper motor enabled"}
2017-01-27 08:27:32.597821 {"Layer":"1","module":"Projector","level":"Notice","msg":"Projector on"}
2017-01-27 08:27:44.374518 {"Layer":"1","module":"Projector","level":"Notice","msg":"Projector on"}
2017-01-27 08:28:13.161979 {"Layer":"1","module":"Hardware","level":"Debug","msg":"Stepper motor enabled"}
2017-01-27 08:28:17.75483 {"Layer":"1","module":"Projector","level":"Notice","msg":"Projector on"}
2017-01-27 08:28:20.588263 {"Layer":"1","module":"Projector","level":"Notice","msg":"Projector on"}
2017-01-27 08:28:21.853336 {"Layer":"1","module":"Projector","level":"Notice","msg":"Projector off"}
2017-01-27 08:28:51.459633 {"Layer":"1","module":"Hardware","level":"Debug","msg":"Stepper motor enabled"}
2017-01-27 08:28:57.595207 {"Layer":"1","module":"Projector","level":"Notice","msg":"Projector on"}
how did you configure nanodlp to turn the projector on?
#6 2017-01-28 15:01:42
Without the debug file it is hard to guess what is wrong.
