Why does the calibration plate take so long to generate? I'm not sure it's even ever going to. It has been "generating" the plate for over half an hour now. Build 1640.
It takes couple of seconds but indicator has issue. So if you refresh page you can start printing.
It doesn't actually print though. My D7 just sits there for a while. No z movement. No Shutter. No Projector. The plate only shows it has 10 layers. 3 mm thick plate at 0.1mm would be 30 layers.
it should repeat layers, so it is fine to have less layers than height. Please share settings which you use to generate the plate.
Plate Depth: 3
Cure times: 2,4,5,6,7,8,9,10
Pillar Width: 5
Pillar Shear: 5
Cube Width: 30
Height: 5
100 micron layer heights
bman,
Unfortunately I could not reproduce the issue with above settings.
Could you share a debug file.
Sure thing. How do I do that?
setup page / tools tab / debug button
