#1 2017-10-12 02:33:24
crankshaft
Flat bottomed item with 3mm overhangs
Hi;
I have a flat-bottomed electronic housing that's approx 50mm x 80mm x 10mm high, with a couple of 90 degree 3 - 5 mm overhangs.
I want to print the base on the plate and don't want the entire structure lifting up, and only add supports to the overhangs, but I can't seem to do this.
The editor refuses to allow the item to sit on the bed and even if I override the z offset, it gets reset back again.
So how can I force the editor to locate the bottom of the object on the plate and only add supports from the plate to the overhang ?
#2 2017-10-12 02:38:09
crankshaft
Re: Flat bottomed item with 3mm overhangs
Ignore this post, there's no problem with the software, only problem is with me !
