1- When you add an stl to new plate with "add" , "center pieces" option not works properly, in previous versions works fine.
2- Some problems when slice objects. I'm using a fridge object , print without hollowing option because i want use my own 3d object hollowed from my modeler app. The problem is that during print your slicer add some layers full solid ( not the hollowed of original design ) 2 or 3 times per model. I can´t find and option in this forum to attatch my 3D object for test.
Please, email sample STL files. shahin at nanodlp.
1. Quite possible as our last calculation does not yield correct result for the rotated screen.
Do you get wrong center even when you have not rotated the plate?
No, in this case the problem is not the rotation of screen, you fix it 2 version before, now the problem is that not auto center objects
