#1 2016-06-02 06:39:02
sgraber
Layer delay math?
Hi! I wanted to know if it is possible to somehow use NanoDLP variables for programically determining the length of time between images being displayed?
For example: I have a LittleRP with a flexvat.  I have NanoDLP set to slowly pull away from my flexvat at 25mm/min to a height of 5mm, then a rapid return at 200mm/min.  Programically, the blank time would be:
(5mm / 25mm/min * 60 sec/min) + (5mm / 200mm/min * 60 sec/min) = 12 sec + 1.5 sec = 13.5 sec
I then normally add about 1.5-2 sec additional time to this calculation so the resin has a bit of time to flow and level under the build platform prior to displaying the next image.
With that added,my blank time would be around 15sec.
Is it somehow possible to do this programically in NanoDLP?  That way I can change either my pull speed and/or my lift height and not have to manually change the
Here is my settings and printer setup:
Profile:  http://i.imgur.com/d0StqMI.png
Hardware Setup:  http://i.imgur.com/UBShnMB.png
Given the variables that we can use for calculations, I have to believe this is somehow possible...I'm just not seeing it.  smile
#2 2016-06-02 17:23:56
sgraber
Re: Layer delay math?
Here's an idea I came up with while chatting with folks on IRC:  use [[Delay x.x]] .
Would the following work in the "GCODE After Each Layer" box?
[[Delay (( [[ZLiftDistance]] / [[ZSpeed]] * 60 ) + ( [[ZLiftDistance]] / 200 * 60 ) + 2.0 ) ]]
It yields [[Delay (12 + 1.5 + 2.0)]] or [[Delay 15.5]]
Thoughts?
Or to make it a bit more readable:
G1 Z[[ZLiftDistance]] F[[ZSpeed]]
[[Delay ( [[ZLiftDistance]] / [[ZSpeed]] * 60 ) ]] ; wait this time for z-lift movement
G1 Z{[[LayerThickness]]-[[ZLiftDistance]]} F200
[[Delay ( ( [[ZLiftDistance]] - [[LayerThickness]] ) / 200 * 60 ) ]] ; wait this time for z-return movement
[[Delay 2.0]] ; wait additional 2.0 sec to allow resin to level under build plate
#3 2016-06-04 05:21:54
Considering priority of gcode parser logic, I believe solution which you came up with is correct. Let me know if it does not work.
#4 2016-06-05 14:13:06
sgraber
Interestingly enough, using multiple brackets, parentheses, etc. doesn't work.  You are only allowed one level deep.  For example, this works:
and outputs:
G1 Z-4.9 F200
However note if you add a second layer of parenthesis:
G1 Z({[[LayerThickness]]-[[ZLiftDistance]]}) F200
outputs this in Terminal:
G1 Z(0.100-5.000) F200
Based on the docs, this should output the same as the first but it doesn't.
#5 2016-06-06 13:36:09
Math parser works on strings insides pairs of {}.
So instead of this
Use this one
G1 Z{([[LayerThickness]]-[[ZLiftDistance]])} F200
#6 2016-06-06 15:47:22
sgraber
Ah-ha!  Ok, that explains it!  Thank you!  smile
