Good evening,
When the machine is not printing, I'm having an issue everytime I enter the Z axis control menu tab.
The axis goes up 50mm. If I change to another tab and enter again the Z menu, another 50mm are added. The axis goes up and I have to reset the RAMPS controller to avoid crashing the spindle.
Find enclosed the debug info.
Where is the problem?.
Thank you for your answer.
Best regards.
I could see G1 Z50 in the program log files. But Z50 is not defined in your config files or in nanodlp itself.
Changing page should not send command, try another browser to see if you could find more clue what is triggering this command.
Good morning,
It seems that was a problem with the RAMPS control board. I downloaded again the firmware and was fixed.
Thank you for your support.
