#1 2017-10-22 14:52:54
ToS
Z-Endstop Position in NanoDLP configurable?
nanodlp seems to be expect the endstop positioned at the top of the z-axis, which basically considers it as an max-endstop.
Is there a way to configure nanodlp in a way so that the z-endstop can be mounted at the bottom as kind of min-endstop instead?
This seams to make more sense to me, as it's more critical to crash the z-axis into the display but driving it to the upper limit.
Also wiring of the endstop switch at the bottom is more easy than at the top.
Maybe I missed an importand argument or it's already configurable in the mentioned way.
Any tipps and arguments are welcome
ToS
#2 2017-10-22 20:03:42
bigfilsing
Re: Z-Endstop Position in NanoDLP configurable?
To the best of my knowledge the end stop position ( max or min) are configured in the control board firmware Not in Nanodlp .... As are the steps per mm, homing direction etc etc
#3 2017-10-22 20:43:51
ToS
There is no control board firmware as I indent to use raspi GPIO's
#4 2017-10-23 01:20:04
bigfilsing
Bottom limit switch control is under development. Scroll to the bottom of this page and you will see it listed under "high priority"    https://www.nanodlp.com/
#5 2017-10-23 06:29:41
ToS
Thats good news! Thanks!
#6 2017-10-23 07:50:28
It is already available on latest versions.
#7 2017-10-23 22:17:24
ToS
@Shahin: Thanks! Really appreciated.    ...but downloaded and tested it today and it either doesn't work for me or at least not as I expected:
When I go to "Z Axis Control" and press "Calibrate Zero Position" the motor starts, but doesn't stop when the bottom endstop switch is triggered.
Same with "Measure Z-Axis length"
#8 2017-10-26 07:10:46
Is it working for manual movements?
#9 2017-10-26 21:48:33
ToS
@Shahin: not quite shure how to interpret your question
#10 2017-10-27 05:08:58
Move it down until it reaches limit switch at bottom. If it passes, it does not work.
