#1 2016-02-17 08:51:58
Latest build changelog
Build #1006
  • Pixel dimming
  • Cloud dashboard
  • Binary communication support w. projectors
  • Command execution to turn projectors on/off
#2 2016-02-19 18:08:19
Re: Latest build changelog
Build #1010
  • Feature: Dimming feature improved
  • Feature: Smarter online dashboard update
  • Bugfix: Plate edit reset layer number - Fixed
  • Bugfix: Connection leaks
#3 2016-02-22 00:03:39
Build #1014
  • Feature: UPnP auto discovery support
  • Feature: Profile Export/Import
  • Bugfix: Log flood on serial port problems
#4 2016-02-23 08:48:45
Build #1021
  • Feature: Set GPIO to HIGH and LOW by GCODE. eg [[GPIOHigh 12]]
  • Feature: New hardware fault detection module, currently supports fault pin on stepper drivers such as DRV8825
  • Bugfix: Miss local IP address on some cases
#5 2016-02-29 16:40:43
Build #1034
  • Feature: Resin and resolution calibration
#6 2016-03-04 19:35:15
Build #1040
  • Feature: Calibration plate generator shear option
  • Feature: USB storage support for plate upload
  • Feature: Projector warmup support
  • Feature: Display more details for calibration plate
  • Bugfix: More details on plate page
  • Bugfix: Shutdown cancel does not work
  • Bugfix: Issue with new raspbian
#7 2016-03-08 21:55:48
Build #1050
  • Feature: Hardware resource monitor
  • Feature: Custom buttons support condition
  • Bugfix: Report problems on graphic stack instead of panicing
#8 2016-03-12 10:00:08
Build #1052
  • Feature: New SD image
  • Feature: Force Stop
  • Feature: Improved setup script
#9 2016-03-16 22:36:48
Build #1061:
  • Feature: Crash/Print recovery for RAMP boards
  • Feature: New gcode keywords PositionChange, PositionSet, CurrentPosition, LayerPosition
  • Feature: Separate resume and start gcodes
  • Feature: Homing in both direction is possible now
  • Bugfix: Shutter problem on rpi3
  • Bugfix: Multiple file upload problem
#10 2016-03-18 09:03:03
Build #1076:
  • Feature: Logging moved to memory, lot less disk IO. Speed improvement on UI
  • Feature: Display number of process being used
  • Change: More efficient thread management
  • Change: Rewrite shutter module to improve stability
  • Change: UI change
  • Bugfix: Get killed on slow syscalls
#11 2016-03-24 21:33:20
Build #1089:
  • Feature: On screen help
  • Feature: Merged all distributions / Distribution change feature
  • Feature: Hidden setup customization feature for 3d printer manufacturers
  • Bugfix: Manual camera button does not work
  • Bugfix: Block active plate during printing
  • Bugfix: Raspian desktop skip rc.local
#12 2016-03-30 10:35:32
Build #1106:
  • Feature: Absolute positing support on z-calibration page
  • Feature: Storage expand from interface
  • Feature: Program crash recovery. Will stop printer on the most of issues instead of crashing
  • Change: More on screen helps
  • Bugfix: Autostop infinitive run
#13 2016-04-01 10:32:34
Build #1115:
  • Feature: Paint and Extrude!
  • Feature: Create plate from single image
  • Feature: Debug info exporter on tools page
  • Feature: Projector power cycle options
#14 2016-04-08 14:20:41
Build #1125:
  • Feature: WiFi manager - RPi3 wireless support
  • Change: Hide extra buttons for RAMP users
  • Bugfix: Paint loading issue
  • Bugfix: Slicer crash recovery
  • Bugfix: Mask grayscale image crash program
  • Bugfix: Manual calibration buttons do not conform to the axis direction
#15 2016-04-17 00:16:14
Build #1139:
  • Feature: Dynamic Cure Time
  • Feature: HDMI signal off/on support
  • Feature: API - Alpha Stage
  • Feature: Terminate button for WiFi connections
  • Bugfix: WiFi module keep trying even without hardware available
  • Bugfix: RAMPS board position gets reset on restart
  • Bugfix: Give RAMPS board some time before sending bootup gcode
  • Bugfix: Editing inactive plate blackout data during printing cause active plate id swap
  • Bugfix: Prevent recursive redirection on missing build file
#16 2016-04-25 06:58:51
Build #1147
  • Feature: Stepper enable/disable buttons for direct control
  • Feature: ETA on dashboard
  • Bugfix: "free list corrupted" error
  • Bugfix: Force stop does not break [[WaitForDoneMessage]]
#17 2016-05-12 16:41:18
Build #1163
  • Feature: Binary STL file support
  • Feature: Enable/Disable mask
  • Feature: White image to help collect floating pieces (Adam's contribution)
  • Feature: More projector power cycle modes
  • Feature: Mute printer sound at the end of print
  • Feature: Default profile
  • Bugfix: Data race cause random printer crash
  • Bugfix: Terminal slowdown
  • Bugfix: Slice render slow down
  • Bugfix: Display wrong layer id on some cases
#18 2016-05-27 07:54:02
Build #1172
  • Feature: Read lamp life
  • Feature: Lamp life could be used to calculate cure time
  • Feature: Share TotalSolidArea and LargestArea in realtime
  • Bugfix: Disable sound throw js error
#19 2016-06-10 14:26:46
Build #1178
  • Feature: Support centre from origin for STL, SLC and SVG files
  • Feature: Advanced permissions
  • Feature: Display CPU temperature
  • Feature: Sparklines for hardware stats
#20 2016-06-22 15:11:28
Build #1183
  • Feature: ASCII STL support
  • Feature: Detect corrupted plates
  • Feature: New line termination options for the projectors
#21 2016-07-15 14:40:33
Build #1194
  • Feature: Dynamic Speed
  • Feature: Send commands to RAMPS through API
  • Feature: Ability to listen on any port
  • Feature: Upgrade to beta version button
  • Feature: Suppressing duplicate logs
  • Bugfix: Layer height limit removed
#22 2016-07-30 17:07:57
Build #1204
  • Feature: Render solid areas with any color
  • Feature: Send custom command to the projector
  • Improvement: Faster PNG generation by lowering deflate compression
  • Improvement: Tighten GPIO pulse generation loop
  • Bugfix: Chart overlap issue on low resolutions
  • Bugfix: Some of the projector types does not working correctly
#23 2016-08-21 06:47:02
Build #1220
  • Feature: Mask generator
  • Feature: Dynamic calibration image generation
  • Feature: New gcode keyword [[TotalNumberOfLayers]]
  • Bugfix: Requesting wifi list before wifi initialization
  • Bugfix: Add stl support to usb device
  • Bugfix: Using dynamic speed and cure time cause infinitive loop
#24 2016-08-26 06:49:21
Build #1221
  • Feature: [[Exec command]] keyword to run external command
  • Feature: [[ExecReturn command]] keyword to run external command and send the result to RAMPS
  • Feature: [[Net url]] keyword to send get request
  • Feature: [[NetReturn url]] keyword to send get request and send the result to RAMPS
#25 2016-11-01 15:04:23
Build #1261
  • Feature: New [[SmallestArea]] and [[AreaCount]] keywords
  • Change: Golang compiler upgrade to 1.7
  • Large number of bugfixes
