Updated to the most actual version - now the LayerSkip value is no more cutting away the rest of the gcode in the "Before Each Layer" field.
Warning 3 2017-12-10 16:49:20.778185 Printing Layer has been skipped
Notice 3 2017-12-10 16:49:19.977706 Terminal Received Data From RAMPS: wait
Notice 3 2017-12-10 16:49:13.978633 Terminal Received Data From RAMPS: ok
Debug 3 2017-12-10 16:49:13.977681 Gcode Delay Printing For 6.8 Seconds
Debug 3 2017-12-10 16:49:13.977289 Gcode Transfering Data
M201 Z 15.0000
G1 Z 10.0000
G1 Z-9.8500
Warning 3 2017-12-10 16:49:13.977248 Gcode Layer set to be skipped
It seems, that the layer ist set to be skipped, but first the remaining Gcode will be executed before the Layer at the end of this gets skipped...
It should skip layer itself not gcode. The issue is that if we skip remaining gcode, any movement and etc will be skipped too.
I do not thinks people currently using this feature so if couple of users agree on how it should be behave we can change it.
thanks for your reply & no problem. I just have seen, that in older versions also the gcode has been cut away. Now I changed the strategy a little bit and the gcode stuff will be executed in the "after the layer" part and all is working fine again.
