As a new user and just learning to print on my DLP printer, I've been frustrated because I can't see the first few layers of the print (bottom up printer) to make sure they are good. So I've been going int the Printer Profile and changing the Lift after Print from 5mm to 25mm. This creates a long 25mm lift on the next exposure cycle and gives me an opportunity to check my print. It has been a great learning aid and one that I'm sure I'll use for many other purposes. But it is a pain to do this and then reset it. So what about a feature on the print control page that allows one to do this right from that page - a Lift after Print override. Ideally it would include a field where you can enter your new lift height but it would also be great to have a 2 speed lift - say the first N mm at the normal lift rate and then the rest happens at a faster speed (user specified) to cut down the time for the long lift. But even without the speed enhancement, a simple Lift after Print override would be very useful.
cheers,
Michael
The initial thought that I had is to create a single custom button on the home page that does a one-time lift when you press it:
G1 Z25 F200
[Delay 5]
G1 Z-25 F200
That said, I'm not sure when that code would be executed when you press the button.
I tested Shane's idea. If the button is configured as Anytime, the lift or lower occurs IMMEDIATELY. And, if you aren't careful with your timing, the running program can interject its commands and cause heartache (i.e. turn on the projector with the part 25mm above the vat floor!). So that does not work. I suspect the Printing option would do the same and the Idle option might make some convenient jog buttons to set things up but won't address my request.
Ok, I wondered if it needed a delay in there, so here's what I'd try next:
G1 Z25 F200
[Delay 10]
G1 Z-25 F200
[Delay 10]
The delays give enough time for the platform to fully extend and decend before the next command. Try it? This needs to go all in 1 button.
The issue is that nanoDLP is running it's program uninterrupted. So even with the delay and auto descend, there is a reasonable probability that nanoDLP is going to start an exposure or make its own Z move.
Yeah I just tested the single button with delay. I was correct, nanoDLP interjects AND you can press this button during an exposure and cause a ruckus.
I used to set auto-stop layers to inspect layers.
I've looked all over and don't see auto-stop layers. Where are they?
ok, I found it on Edit Plate called Stop Layers. That's fine but does not give me the explicit control that I would like. For instance, if I hear or don't hear a peal from my vat film, I'd like to check on the next cycle to see what happened. Preprogramming stops doesn't accomplish that. Once I have printing more or less routine I may not need it but right now it would be a great tool for leaning and later, I would like to do some creative things like stop and raise, swirl in a complimentary color of resin, and then continue to create multi-colored objects. I did this with yellow and green on a toad print today and he results were interesting.
Why not use stop/resume buttons?
stop does not raise the build platform up so I can see the print
In fact, auto-stop layers wouldn't raise the build platform either would they?
Modify "GCode - End of Print" to lift it to height you need.
Doesn't that only affect the actual end of print? Or is it called into play with auto-stop layers too? I already have gcode set there to raise 25mm so I can remove the part.
Bad naming, yes it runs even on stop caused by auto-stop or manual stop.
Ok, since I already have it set up I can test it.
The Stop button actually cancels the print.
If you set resume box values correctly, resume will return everything to expected position.
and when I tried to click Restart (not resume as above) nanoDLP apparently crashed and "site can not be reached". This happens quite a bit.
Oh, restart will do hardware restart, you should use resume button after stop.
I can't find this "resume" button. On the screen after I click Stop there is a Power Off and Restart buttons. Are you talking about the resume button on the Plates tab? If so, that is even more work and confusion and less control than what I've been doing.
First button on main page, https://pageshot.net/fipMCqo0yxmAJkK6/127.0.0.1
So, yes I would have to switch screens to get to it. And unless that button is dynamically added when the Stop button is pressed, I do not see it on my main screen.
At this point, I am going to move on to something more productive to do. If this were an open source project I could have implemented this feature in less time than I've spent trying to convince you there is a need.
I was actually going to mention this exact route:
I have this in my Stop GCODE section:
G1 Z25 F200
And I now have this in my Resume GCODE section:
G1 Z-25 F200
[Delay {25/200*60}]
Hit the STOP button on the home screen, NanoDLP stops the print and indexes up 25mm. I hit the Resume key and the print indexes back down and starts printing again.
Resume button dynamically added after complete stop.
