#1 2016-03-03 14:03:02
Rastati
Schematics infos!
I am trying to build a DLP printer with a RPi 2. I just came across the schematics and I cant identify what is the Max232 for.
Is it to be able to turn off the projector?
Also I tough that the PWM of the raspberry Pi could only be achieved with Pin 12-GPIO18 am I wrong?
Thanks a lot!
#2 2016-03-03 17:31:58
Re: Schematics infos!
Rastati,
You are right about MAX232, it is optional and personally I prefer separate usb serial adaptor.
No, it is possible to use any general purpose gpio to send PWM
#3 2017-01-27 21:55:09
arpinus
Shahin wrote:
Rastati,
The nanoDLP schematic and PCB board design is not very clear for me.
There are some errors on PBC design and possible on schematic too; some connections are... "open".
It is possible to have a clear design that helps to better understand how to connect directly or indirectly?
It might help a unitary schematic from GPiO to motor steppers and power, even if is done by hand...
Thanks,
#4 2017-01-28 14:38:38
You are right routing software messed up export.
I will update exports on the website in couple of minutes.
Connect two black dots and red dots with wire.
#5 2017-04-20 22:48:31
Kochevnik
Hi
Tell me please will this work?
May be I forget something?
#6 2017-04-21 09:42:10
Kochevnik
And one more question. I want to rebuild lcd printer like wanhao 7. I need to control z axis and uv led. Schematic for z axis a posted, but how to control uv led? What pins I should use to control uv led?
#7 2017-04-21 20:45:12
Kochevnik
Hello?? Can someone help me? (((
#8 2017-04-30 06:06:03
Kochevnik
Anybody here?
#9 2017-05-16 20:08:53
Superdave42
I'm also looking how to control LED array from the Pi3
#10 2017-05-16 20:10:30
Kochevnik
I found. I think so. When lcd plate will be ready, I will post it here
#11 2017-05-16 20:17:23
Superdave42
Alright cool, thank you
#12 2017-05-19 06:04:29
arpinus
Any update?
It your schematic works?
I would like to understand how to connect, and why is only one contact limit (it is limiting up, or down?):
schematic
