I think the title says it all
You have solved nearly every area where big gains in print speed could be achieved ( Time to display, calculators, usability )
This is the last man standing imo.
(might only be achievable with a pi daugtherboard, unsure how the arduino based controllers would react to it given that they already employ acceleration values )
Good idea for direct control.
There are two ways to handle acceleration.
Realtime pulse length calculation, providing realtime formula calculation will effect performance.
Pre-calculated pulse length. Increase early delay and memory usage to handle formula.
Will try implement this.
So much thanks !
I thought about other ways of doing it "manually" but nothing came to my mind quickly
Maybe real time is feasible as we only move a single axis between to fixed points, but precalculating while slicing could work aswell, for the calculators we would need the possibility to tie the accel "rates" to [[buildarea]].
Is there a certain daughterboard you recommend for using with pi and Nanodlp ?
I have not used one, maybe somebody else could offer advice.
I found this guy here: https://plus.google.com/100170060322292 … KC5ueGNPbZ that looks really promising !
For calculating Realtime maybe it lessens the burden on the pi if you break up the exponential function into maybe just 5 hard points, that should be sufficiently precise for a very smooth peel and a just as smooth stop after retract in the vat for the next layer.
Have you tried custom speed control?
