Hi everyone!
The implementation of the mask is so cool, but how do you generate this mask? If you know a easy way for doing this, please tell me. (I have radiometer in order to know the brightness).
Thanks in advance!!!
Here is described how to make a mask by means of uv sensor.
http://www.buildyourownsla.com/forum/vi … f=5&t=3684
I , however, was not successful with both a UV sensor or a light sensor.
With the printing of cylinders over the entire platform and its dimensional variation I could then create a working mask,
with the help of the software Rhino .
Nanodlp has now implemented an even better mask generation algorithm similar to that on buildyourownsla.com, but better in that you don't need Rhino or magic numbers or formulas to determine the mask, and any UV sensor in the cure range of the resin can be used without calibration due to the set point methodology.
