#1 2017-12-01 03:49:00
mkbot
Speeds clarified
I'm just trying to clarify some setting speed, and the built in help is very helpful. However it would be great to clarify a few things. Particularly those related to what speeds are used during the return/retract to resin.
1) Min Speed - On Setup: Being used when prints dip into resin. Is this on the first entry into Resin at the start of a print job? Or everytime the print goes back to the resin after each layer (for instance CW calls this retract speed)?
1b) Max Speed - On Profile: Max speed during printing. Or does this apply to both lift and retract phases (depending on the response above)?
2) Startup Speed - On Setup: Being used for acceleration. Is the unit for this um/s2? Just curious to understand.
3) Max Speed - On Setup: Being used as the top speed when printer is not printing. I know this applies to every manual gcode sent (manual moves, "stir", etc.), does this also apply to the final lift after a print?
4) Dynamic Speed - On Profile: Override every speed exluding startup speed during printing. Again does this apply to the retract as well as the lift? Or just the lift?
Thanks,
Marc
#2 2017-12-01 05:31:29
Re: Speeds clarified
1) True
1b) True
2) True
3) True, Yes
4) Yes both
#3 2017-12-01 14:13:42
mkbot
Hi Shahin. Thanks for responding. I think you unfortunately missed my most critical questions after the the first two statements. Sorry if I was a little unclear by adding them after the "help" statements. I'm just a little confused by the true/false response on those since I'm curious which of the multiple scenarios is the correct assumption.  Essentially I'm trying to figure out which parameter: 1) controls the speed at which we return to the resin after every layer. Hopefully that's separate from the lift phase. And to a lesser important extent 2) what controls the initial drop into resin at the start of a print.
#4 2017-12-01 20:10:37
No speed for return and lift are same, except if you write your own dynamic speed.
Until reach to resin level, max speed, after that min speed both from setup
#5 2017-12-07 10:43:34
ariesraza2010
Hi,1
1. How to i calibrate  light intensity for mask generation.??? i m facing some problems,
2. what is the speed of motor for lift after print
