Hi guys
Apologies if this has been covered before Ive been readign for 2 hours and havent found a similar issue.
So i have a RPI3 and a ramps 1.4 board with just a single stepper driver on the Z axis with a stock 1.8 deg 1.25amp stepper motor,
Ive tested the ramps with the standard test sketch as well as stock Marlin and used pronterface to control.All works fine
SO then i connected to the RPI3
Couldnt get it to work so used SSH to check the /dev path and corrected that in my path set up . That cleared the serial connection issue.
But now im getting 'Serial communication Error short write" and have no idea what this means.
All help appreciated Thanks
Are you sure the serial port address is correct?
Thanks for the reply
Is that different to the path ? im not very conversant with Linux / Raspi
No it is same. I guess it is wrong address or it has an issue.
Thanks again for the reply
CLearly i need to do some more research on this . Ill report back when i know more
Cheers
Well i reinstalled everything from scratch and its working now . Thanks for your patience and support.
Looking back i think i may have typed the letter cap "O" instead of the number "0" in /dev/ttyUSB0
