#1 2017-04-11 02:17:02
gman9500
nanodlp config.txt file doesn't appear to be turning on LCD on printer
Hi there!
I  have a new Wanhao Duplicator 7 SLA\resin printer
After 2 attempts, nothing printed. I ws trying to print that fancy small cube stl using FTD soft white
It looks like the  HDMI LCD is not coming on. When I go  to the projector calibration and select a pattern, I don't see a pattern generated. The UV LED matrix does comes on however, but no pattern.
I have nanodlp configured per http://3dprinterwiki.info/wiki/wanhao-d … ettings-2/
It is getting a signal. When I look inside,  there is a green led that is on solid, but when I unplug the the hdmi cable, it starts to blink.
I scoured the internet to see if there was a way to find out if nanodlp was detecting the hdfmi lcd screen
I found if I ran tvservice and parse it I can.
http://www.opentechguides.com/how-to/ar … tting.html
Looking at the edid file looks like its not being detected and configured properly if at all(Below this is the config file)
Parsing edid.dat...
HDMI:EDID version 1.3, 1 extensions, unknown aspect ratio
HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
HDMI:EDID found monitor name descriptor tag 0xfc
HDMI:EDID monitor name is V_R__________▒
HDMI:EDID found monitor S/N descriptor tag 0xff
HDMI:EDID found monitor range descriptor tag 0xfd
HDMI:EDID monitor range offsets: V min=0, V max=0, H min=0, H max=0
HDMI:EDID monitor range: vertical is 23-75 Hz, horizontal is 15-240 kHz, max pixel clock is 300 MHz
HDMI:EDID monitor range does not support GTF
HDMI:EDID failed to find a matching detail format for 1440x2560p hfp:60 hs:10 hbp:35 vfp:4 vs:2 vbp:2 pixel clock:198 MHz
HDMI:EDID calculated refresh rate is 50 Hz
HDMI:EDID guessing the format to be 1440x2560p @50 Hz
HDMI:EDID found unknown detail timing format: 1440x2560p hfp:60 hs:10 hbp:35 vfp:4 vs:2 vbp:2 pixel clock:198 MHz
HDMI:EDID established timing I/II bytes are 00 00 00
HDMI:EDID standard timings block x 8: 0x0000 0000 0000 0000 0000 0000 0000 0000
HDMI:EDID parsing v3 CEA extension 0
HDMI:EDID monitor support - underscan IT formats:no, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:4
HDMI:EDID does not understand CEA format code 0
HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48|88|96|176|192 kHz, sample size: 16|20|24 bits
HDMI:EDID found HDMI VSDB length 6
HDMI:EDID HDMI VSDB has physical address 3.0.0.0
HDMI:EDID HDMI VSDB supports AI:yes, dual link DVI:no
HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:no 30-bit:no DC_yuv444:no
HDMI:EDID HDMI VSDB has no latency information
HDMI:EDID adding mandatory support for DMT (4) 640x480p @ 60Hz
HDMI:EDID adding mandatory support for CEA (1) 640x480p @ 60Hz
HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
HDMI:EDID no known preferred format has been set
HDMI:EDID filtering preferred group has been changed from Invalid to CEA
HDMI:EDID best score mode initialised to CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 0)
HDMI:EDID best score mode is now CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 61864)
HDMI:EDID DMT mode (4) 640x480p @ 60 Hz with pixel clock 25 MHz has a score of 18432
HDMI:EDID preferred mode is updated to CEA (1) 640x480p @ 60 Hz with pixel clock 25200000 Hz
HDMI:EDID has HDMI support and audio support
edid_parser exited with code 0
The Failed comments are what I noticed in the parse. Like the lcd isn't comaptibe? Even though the below is what is given to us for configuring it.
Here is the config file(this is the data that is added at the end of the  exisitng config file
# Wanhao D7 nanodlp config
# V1.0 3-feb-2017
# CAMERA SETTINGS ( 1 = ON, 0 = OFF)
#start_x=1
disable_camera_led=1
# DISPLAY SETTINGS
display_rotate=0x10000
hdmi_force_hotplug=1
hdmi_timings=1440 0 50 10 35 2560 0 4 2 2 0 0 0 50 0 198000000 0
hdmi_group=2
hdmi_mode=87
hdmi_pixel_freq_limit=500000000
hvs_priority=0x32ff
max_framebuffer_width=1440
max_framebuffer_height=2560
framebuffer_depth=24
framebuffer_ignore_alpha=1
config_hdmi_boost=4
gpu_mem=192
Not sure what I m missing. Any  ideas?
Is there a way to find out what the LCD parameters should be?
Daryl
#2 2017-04-11 07:44:20
Re: nanodlp config.txt file doesn't appear to be turning on LCD on printer
You can get some parameters by connecting driver to linux pc. I am not sure about windows.
RPi is not good in detecting displays specially non-standard ones.
See if you could get image on PC, maybe it is a display failure.
#3 2017-04-11 16:09:58
macdarren
I had this problem too....I did get a setup that works....I will see if I can post it when I get to the printer...I get good information and help for the D7 at:
https://www.facebook.com/groups/287910088208745/
Also when I was trying to work this out I plugged the HDMI into a monitor...It is easier to see what is happening as there is no back light on the D7 except the UV which you have to turn on to see the LCD and looking down into the UV source didn't seem like a great idea.
#4 2017-04-11 21:31:31
macdarren
Just checked and my config.txt is the same as yours and it works with my D7....
#5 2017-04-12 02:23:42
gman9500
Hey thanks guys
Yeah I plugged it into my regular monitor and after changing the hdmi_mode to 1 It did displaythe first layer of a plate
Hey macderren I do know that site and have beewn reading it extensiveily and saw earlier today about how to manually turn on the  UV LED matrix (Though some say it turns on the LCD, it doesn't) and it gave me an idea
Reconnect hdmi back to the D7
Send gcode M106  via the terminal to the D7 to turn on the UV led
Make sure the bed is raised so that you can see the screen
Do a sudo reboot and you see it  exit the nanodlp software and display the rpi logo on the lcd screen with the UV led matricx backlight on so that you can see the screen
So it works
Then just to make sure it was displaying the plate to be displayed, I figured out how to raise the bed after starting a plate witih the Gcode. And I saw it displaying the first layer of the rook. Nice white circle.  The  small cube plate is just to smale to discern on the screen.
I just now need to figure out why the resin (FTD white) isn't curing to the plate. or curing at all for that matter from the UV led.
Don't know how bright the UV leds are  supposed to be. Doesn't seem very bright to me.  Yeah, I'm not lookign at it for long period of time and not directly. Seems similiar to blacklight, but I think dif freq.
Did see someone on the FB forum mention something about sanding the bed with a very fine grit to get the resin to stick
Or its the FEP sheet which is really foggy.
Daryl
#6 2017-04-12 07:08:37
macdarren
Glad you got it going..
I didn't sand my plate but my resin sticks really well...My FEP is not overly clear anymore but still works.....I haven't tried the FTD white but several others seem to be getting it to work on the D7.
Just ordered some Monucure hoping that works for me as well as it did for others.  The LED is not super bright but it need not be as most of the light that does the curing should be outside or at the very edge of visible.  But no curing at all seems like something odd is happening.  maybe test some blob of resin just in the vat with the light on and LCD set to white for a few minutes and see if it cures at all?
#7 2017-04-12 14:43:11
gman9500
Ok thanks that gives me a frame of reference.
The blob printed when I did a different  plate(the rook)
So I did a full print of the make rook and it printed great!
I'd post a pic , but I can't figure out how to.
Yeah I got that monocure clear a couple days ago(and a couple other colors as well since shipping is high ) . Will be trying it this weekend
I think FTD has already ran out from what I saw of their resins. Monocure may be soon I'm sure
