#1 2017-11-09 10:52:46
Kaelthas
nanodlp + wanhao d7 + ookuma castable resin
Hello everyone,
it's my first post. i have a d7 with nanodlp rpi3.
i'd like to use oo-kuma castable resin, i tried something and nothing happened. how can i print something?
it is never sticking to lift. how can i set oo-kuma castable resin profile?
#2 2017-11-09 11:00:02
bigfilsing
Re: nanodlp + wanhao d7 + ookuma castable resin
It is often best to use an existing profile ( imported or default) and edit that. Im confident somebody on the D7 FB page would share a working profile ( I don't have a D7 or use FB so can't help sorry)
#3 2017-11-09 12:18:16
Kaelthas
bigfilsing wrote:
It is often best to use an existing profile ( imported or default) and edit that. Im confident somebody on the D7 page would share a working profile ( idont have a D& or use FB so cant help sorry)
thank you, im trying now.
#4 2017-11-10 08:00:11
Kaelthas
well, i guess my problem is about nanodlp, I'm an amateur and i can't use it.
i created this profile and  tried many things and nothing happened. neither in vat  nor on plate.
#5 2017-11-10 09:05:43
bigfilsing
Import a profile from somebody then try a dry run ( no resin in vat) when its working you can edit the various sections to suit your particular resin
#6 2017-11-10 10:26:07
Kaelthas
lcd screen is working. how can i calculate Z lift sequence times ? i mean with this profiles... is it allright?
#7 2017-11-10 13:36:27
MaxJewels
why the colour are green in edit profile?
#8 2017-11-10 13:46:28
Kaelthas
because it is green smile
#9 2017-11-13 17:12:47
jamesarm97
FYI, I made that same mistake on mine. I set it to grey once. This turns out to be the color actually shown on the LCD when curing the part so it will show Green instead of all White and will not let through as much UV light.
