#26 2017-07-01 20:55:23
backXslash
Re: Odd Crash On 1540
Shahin wrote:
Unfortunately wide range of issues from OS to the software and hardware issues could cause this kind of error message. So it is not helpful until I can reproduce the issue locally.
Anything I can do to help? I can set my unit up for SSH for you, if need be.
#27 2017-07-02 02:08:30
backXslash
If it helps, I've been testing. It seems to fail fairly consistently around 350 layers. Once restarted it's again fairly consistent at ~300 USB layer intervals.
#28 2017-07-02 05:40:55
Thank you, trying nanodlp printing and movement by direct control for few days. If I could not reproduce will switch to your settings and test again.
#29 2017-07-03 23:50:59
backXslash
Any news?
#30 2017-07-04 02:43:47
backXslash
Well, I've swapped in a brand new RPi3 and a brand new SD card with a 100% untouched NanoDLP image freshly downloaded from the site. Once it booted for the first time, I selected NanoDLP generic, rebooted, expanded the file system, rebooted, allowed the built in updater to upgrade to the beta, and I'm now trying a test print.
We'll see what happens.
#31 2017-07-04 06:03:52
It will takes couple of days to confirm the issue. But I have asked around, apparently no one with similar setup experience this issue. But I will test with your exact print profile too.
#32 2017-07-04 19:19:02
backXslash
Well, this one may remain in the mystery pile. After swapping the RPi, new SD card, and fresh flash of NanoDLP the issue seems to have been resolved. I can only surmise that it's some kind of freak compounded upgrade bug.
#33 2017-07-04 20:02:05
Good to know it get solved. Nanodlp is single binary program so upgrade process could not cause serious issues.
#34 2017-07-04 20:47:43
backXslash
That's the theory I suppose, but I was lumping in the actual OS updates and such. I used the NanoDLP image downloaded fresh from the site and didn't apt-get update / dist-upgrade or anything. Just allowed NanoDLP to update itself then hand copied my settings over to avoid a potential issue in the generated files from my previous version.
