Ive just installed Nano DLP on a raspberry pi 2 with Raspberry Jessie lite and Strech lite and after the installation, on next boot, the machine boot fine, the screen goes black (nanodlp take controle of it) and after that, nothing works. The raspberry pi doesn't respond and the webserver of nanoDLP is not reachable. Error 404.
I tested another SD card with NanoDLP installed since few month and everything works fine so no problem from my pi of so.
Could you help me?
Could you ping rpi? Are you sure about IP address?
The pi has always the same ip,
I will test ping it but I thing the ping is ok.
I ´ve just tested to take an old nanodlp version on jessie and update it and it works.
So the latest version of nanodlp works but the bash script to install it directly in advanced mode didn't work...
Not much changed on setup scripts in last couple of months. I guess IP change was the culprit. (If it not forced by router DHCP)
