hi boys, my printer has stopped working properly cause the z axis doesnt move when homing, but if i move with grbl it seems to work fine. if i use my old raspi3 i get suppresing duplicate logs message when start printing and printer doesnt work. with other raspi3 (newer) i get "undefined feed rate" error (remember it works properly with grbl). Wtf with my dammit configuration???
log:
Level Layer Time Module Details
Notice 1 2017-06-26 14:08:48.416986 Terminal Received Data From RAMPS: ok
Notice 1 2017-06-26 14:08:48.416647 Terminal Received Data From RAMPS: error: Undefined feed rate
Debug 1 2017-06-26 14:08:48.409066 Gcode Transfering Data G1 Z-100.00
Debug 1 2017-06-20 16:17:49.743312 WiFi Connected to evoPRINT3D
Notice 1 2017-06-20 16:17:44.763972 Terminal Received Data From RAMPS: ok
Notice 1 2017-06-20 16:17:44.763748 Terminal Received Data From RAMPS: ok
Notice 1 2017-06-20 16:17:44.671281 Terminal Received Data From RAMPS: ok
Notice 1 2017-06-20 16:17:44.670954 Terminal Received Data From RAMPS: error: Setting disabled
Info 1 2017-06-20 16:17:44.670577 Logging Suppressing duplicate logs
Notice 1 2017-06-20 16:17:44.670331 Terminal Received Data From RAMPS: ok
Notice 1 2017-06-20 16:17:44.670048 Terminal Received Data From RAMPS: ok
Notice 1 2017-06-20 16:17:44.653087 Terminal Received Data From RAMPS: ok
Info 1 2017-06-20 16:17:44.648891 RAMPS Sync Waiting for done message from RAMPS
Debug 1 2017-06-20 16:17:44.648744 Gcode Transfering Data $X ; Unlock GRBL just in case
G91 ; Put positioning in relative mode
$H ; Home GRBL
G4 P0.1; SolidRay movement sync
Notice 1 2017-06-20 16:17:41.253922 Terminal Received Data From RAMPS: Grbl 0.9j ['$' for help]
Notice 1 2017-06-20 16:17:41.25371 Terminal Received Data From RAMPS:
Warning 1 2017-06-20 16:17:39.77473 WIFI Connecting to evoPRINT3D
Debug 1 2017-06-20 16:17:39.735746 WiFi Status Monitoring
Warning 1 2017-06-20 16:17:39.733737 WIFI WIFI interface wlan0 detected
Debug 1 2017-06-20 16:17:39.647531 Shutter Shutter Close
Notice 1 2017-06-20 16:17:39.647515 Terminal Terminal Reader Activated
Debug 1 2017-06-20 16:17:39.647466 Hardware Stepper motor enabled
Notice 1 2017-06-20 16:17:39.618746 Hardware Initializing build # 1535 - generic
config:
# For more options and information see
# http://www.raspberrypi.org/documentatio … fig-txt.md
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
# disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
hdmi_pixel_encoding=2
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
start_x=1
gpu_mem=128
#core_freq=250
#sdram_freq=400
#over_voltage=0
#Smaller framebuffer
#framebuffer_depth=8
#framebuffer_ignore_alpha=1
#framebuffer_width=1920
#framebuffer_height=1080
disable_camera_led=1
dtparam=i2c1=on
dtparam=i2c_arm=on
disable_overscan= 1
You should add feedrate in front of movements for better compatibility.
G1 F200 Z1
yes, i can do that when sending gcode into terminal, but when homing i dont know how to do it. i want to copy my setup here:
Bootup Gcode
$H ; Home GRBL
[[WaitForDoneMessage]] ; Wait until movement completed
Start of Print Gcode
$X
G90
G4 P0.1
G92 Z0
[[PositionSet 0]]
resume print gcode
$X
G90
G92 Z[[CurrentPosition]]
G1 Z[[LayerPosition]] F100
G4 P0.1
print stop gcode
$X ; Unlock GRBL just in case we hit the bottom endstop
G01 Z+1 F100 ; Move away from the end stop so GRBL doesn't freak out
$H ; Home the Z axis to bring the print up out of the resin
when i set feedrate in terminal z-axis moves properly, this is the log:
Info 1 2017-06-26 14:16:44.070503 Logging Suppressing duplicate logs
Notice 1 2017-06-26 14:16:44.07016 Terminal Received Data From RAMPS: ok
Notice 1 2017-06-26 14:16:44.06991 Terminal Received Data From RAMPS: ok
Notice 1 2017-06-26 14:16:44.069633 Terminal Received Data From RAMPS: ok
Debug 1 2017-06-26 14:16:44.062523 Gcode Transfering Data G1 F200 Z50
in the first message print gets stuck when starts printing...
here the complete log when i start printing (printer does nothing)
Notice 1 2017-06-26 14:25:13.073086 Terminal Received Data From RAMPS: ok
Notice 1 2017-06-26 14:25:13.072809 Terminal Received Data From RAMPS: ok
Notice 1 2017-06-26 14:25:11.799182 Terminal Received Data From RAMPS: ok
Notice 1 2017-06-26 14:25:11.798648 Terminal Received Data From RAMPS: error: Not idle
Info 1 2017-06-26 14:25:11.77909 Logging Suppressing duplicate logs
Notice 1 2017-06-26 14:25:11.775268 Terminal Received Data From RAMPS: ok
Notice 1 2017-06-26 14:25:11.77493 Terminal Received Data From RAMPS: ok
Notice 1 2017-06-26 14:25:11.774681 Terminal Received Data From RAMPS: ok
Info 1 2017-06-26 14:25:11.771947 RAMPS Sync Waiting for done message from RAMPS
Debug 1 2017-06-26 14:25:11.771761 Gcode Transfering Data $X ; Unlock GRBL just in case we hit the bottom endstop
Notice 1 2017-06-26 14:25:11.770818 Terminal Received Data From RAMPS: ok
Warning 1 2017-06-26 14:25:11.770546 Printing Stop Command Received
Debug 1 2017-06-26 14:25:11.77022 Shutter Shutter Close
Debug 1 2017-06-26 14:25:11.770113 Image Clear screen
Notice 1 2017-06-26 14:25:11.768951 Gcode Position set to 0
Debug 1 2017-06-26 14:25:11.768698 Gcode Transfering Data ; Wait until movement completed
Debug 1 2017-06-26 14:25:11.768448 Gcode Transfering Data
G92 Z0
Info 1 2017-06-26 14:25:11.768332 RAMPS Sync Ready for the next RAMPS movement
Info 1 2017-06-26 14:25:11.768231 RAMPS Sync Ready for the next RAMPS movement
Info 1 2017-06-26 14:25:11.767858 RAMPS Sync Done message from RAMPS has been received
Info 1 2017-06-26 14:24:40.77206 Logging Suppressing duplicate logs
Notice 1 2017-06-26 14:24:40.771808 Terminal Received Data From RAMPS: ok
Notice 1 2017-06-26 14:24:40.771567 Terminal Received Data From RAMPS: ok
Notice 1 2017-06-26 14:24:40.771315 Terminal Received Data From RAMPS: ok
Info 1 2017-06-26 14:24:40.766979 RAMPS Sync Waiting for done message from RAMPS
Debug 1 2017-06-26 14:24:40.766863 Gcode Transfering Data $X
G90
G4 P0.1
can anyone provide his machine setup and resin profile settings .json?
You need to use patched firmware (marlin/grbl) for [[WaitForDoneMessage]].
