Dear administrator
Due to different printers and Resin in different Cure Time when the width of the print will be different, that is, Cure Time, the longer the greater width, whether the "Resin Profiles" add a set "X/Y compensation", you can manually set the edge of larger or smaller slice images, so that after the printing measurement of size, can input of pixels, to correct the size of the printing precision.
We have it already
I try to "X/Y Size Modifier" will be changed to 0, then slice, then the numerical to 10, then slice, the two images are compared, and then found that just proportion will be magnified, the result of this is not I want, I want to by entering a value, on the premise of proportion does not change, makes the image change coarse or fine, so I can correct for Cure Time due to the different printing results became thicker or thinner.
Because the longer the Cure Time,
The harder it is to print,
It's going to get thicker,
I want to make it harder and keep the same thickness.Can you help me?
