I would like some way to File and sort my plates...
A simple flat list is fine until you get to ten or so plates then it gets to be messy.
In addition I have a small printer so I often find I have to break my projects into smaller parts not all
of which can be on a single plate. A way to keep certain plates together in a 'folder' would be helpful.
Pretty much as the number of plates grows there needs to be something akin to a computer file system
to keep track of things.
I tend to prefer always active searches using meta data and a flat file system to actual file and directory systems,
but others may have a different opinion.
Searching could be easily added but majority would have less than 30~50 plate on their SD card.
Wow 30-50...my other printers have hundreds....
If you could add a comment section to each plate, then allow us to add buttons which perform searches like 'contains xxxxx, xxxxx'. Pressing the button would then hide all plates that do not meet the criteria, this would probably suffice for me at least until I build up my library of resin based prints.
