#1 2017-04-25 05:56:04
macdarren
last plate time and duration
I would like to see a couple info lines on a plate after it has been printed:
would be nice if it showed LAST PRINT TIME  and TIME REQUIRED FOR PRINT
This would just be helpful when comparing print tweaks and also when selecting a previously printed model to reprint...knowing how long it will take
helps decide the order of multi part print jobs.
#2 2017-04-25 06:37:12
Re: last plate time and duration
Time requirement is difficult, currently it just calculate avg of layers time being printed. Simply NanoDLP does not know when RAMPS going to complete an action.
#3 2017-04-25 18:18:48
macdarren
I know this I am suggesting after a print info be retained....simply that when the print is started a time stamp is made like in the logs then when the last command executes the difference between start time and current time will be the time to print...
it doesn't have to be perfect but it should be pretty close assuming yo change nothing from print to print ... if you wanted to juice it up a bit you could subtract any user pause time but I don't really thing that is critical.  obvious the date and time of the last time this print was completed would also be available just for general information.  no real calculations involved in this type of system....
