I am using an LED to cure the resin during slice exposure.
I have the relay working by using gcode on the terminal,
but where do I put that gcode so the relay turns on/off during the exposure time of the slice?
Hi
Setup>Hardware> Shutter Open Gcode & Shutter close Gcode
Ahh..
I thought the shutter would happen before and after the actual exposure..
I will check it thank you
Edit: this works if I turn off 'wait before print' under the resin profile.
Otherwise the 'shutter' gcode will run and then wait for a bit until the slice image actually appears.
As far as i know the "exposure time" is exactly the time between the "shutter open" & "shutter closed" commands
