#1 2017-03-03 07:56:45
color
Projector mask generator question
Hello, where is the location of the mask  file generated by Mask generator? I am trying to upload the mask but don't know where to search the file?
#2 2017-03-03 08:20:58
Re: Projector mask generator question
/home/pi/printer/public/plates/
#3 2017-03-03 08:29:40
color
Well, after I click "Browse" Nanodlp open a new window, but these are Windows directory and I can not go to /home/pi
#4 2017-03-03 08:31:31
Ok, I just got what you means. Mask file automatically generated on Pi and not on your windows pc and replaces main mask automatically.
#5 2017-03-03 08:35:18
color
What if I incidently remove the mask? How to place the generated mask again? Or I should make the UV scaning again and generate a new mask?
#6 2017-03-03 08:39:40
If you would like to take a backup, easiest way is to enter address below (change ip to rpi's ip)
http://ip/static/plates/mask.png
#7 2017-03-03 08:50:30
color
After entering this, the new window open with message "not found" Is ths mean there are no stored file in the directory?
#8 2017-03-03 08:52:31
Yes, please provide screenshot.
#9 2017-03-03 08:58:40
color
I can not upload image here but I removed the mask before open this discusion.
I have made a quick test with a new mask,and now I understand how to proceed. Unfortunately I will need to make all the UV scanning again. Thank you for the support Shahi.
#10 2017-03-09 18:10:42
color
Hello, for some reason after generating the mask and click "save" my png file looks like this:
What I am doing wrong?
#11 2017-03-09 20:27:39
backXslash
https://s18.postimg.org/48rrpn3at/mask_1.png
Having a similar problem. The mask generator doesn't seem to be "smoothing" like it did in previous versions.
Mask Problem Example
#12 2017-03-09 20:56:16
color
Is this mask usable?
#13 2017-03-09 21:10:28
backXslash
Hell no
#14 2017-03-09 22:34:01
Bug fixed. Try the beta version.
#15 2017-03-10 17:43:30
color
Build 1367 = the same situation
#16 2017-03-10 18:14:36
It is not same, you need more measurement points if you need something more smooth.
#17 2017-03-10 18:28:05
color
What is the recommended number of cells for 39 micron XY resolution to have a smooth image? I have had a wrong understanding that the software will make some calculation after scanning and the generated image will look like a "cloud", not  like mine.
#18 2017-03-10 19:06:41
More bluring will cause cloudy looks, but it would not translate to better quality.
I add an option to control amount of bluring to the beta version.
What you have shared in my opinion is hardly could happens with projector lens. Segment needs to be much closer in brightness to each other.
#19 2017-03-10 19:30:36
color
Thanks Shahin, I will make a new scaning with more cells and will test how the mask will work. My current mask is just a quick test to see how the mask generator work.
#20 2017-04-05 02:04:16
elshad66
1,,,For example, I adjusted the mask to the points, then brought it to the screen
A non-smoothed mask is displayed,
With square boundaries, which makes verification difficult
This mask is that in the middle,
As output to the screen, the smoothed mask, which is on the right?
2,,,If the mask is ready and saved
How to output it again to the mask generator,To edit
Do not start every time from the beginning
