Hey, Wisar! Let me know if the remote slicing works for you. It is not working for me (I updated the rPi3 version to the latest one, but not the Windows one... could be that?).
Thanks for the support, Shahin! And I'm with Will: I would me more than happy to contribute in a monetary way to the nanoDLP development.
--- EDIT ---
Nevermind! The IP of the Windows machine was incorrect! The remote slicing is working perfectly.
--- EDIT ---
Where did you change the ip?
You can do that from the SETUP page on nanoDLP. The parameter is almost at the bottom of the page, if I remember correctly. If you do not see that option, you might need to update it to a more recent version to be able to use remote slicing.
It's also worth mentioning that I have been using this feature for the last week and it works like a charm!
which port did you use, I cant put it to work.
thanks
I used the default, 8080. You will need to have nanoDLP running in the remote machine as well, so you will have a total of 2 instances of it running: assuming you are using a rPi and a Windows machine, once they are you will be able to access each of them in your browser, and watching them interacting when the remote slicing process kicks in.
This is exactly what I'm doing but doesnt word
