#1 2017-10-09 21:09:10
Doug
Mask changes when generated
Hi I am trying to calibrate my screen but when I generate my mask it seems to change.
In both images I'm measuring in the same spot, first one in mask form the second I made a plate the same size of the screen.
I use Bluring Radius 1 and 30 with the same results, and in one side of the screen seems to work well.
any Idea?
Thanks all
#2 2017-10-09 21:12:33
Doug
Re: Mask changes when generated
The other side changes less but to more intensity
#3 2017-10-11 15:58:33
The issue is only on side or on the whole surface? Are you using DLP or LCD based printer?
#4 2017-10-11 16:46:11
Doug
Hi, one side and LCD screen.
#5 2017-10-11 19:34:44
Could you confirm if we shift measurement box around half of each box we get correct value?
#6 2017-10-12 06:00:43
Doug
Hi I will try it and get you to know.
Another question in mask form, I'm trying to use my sensor and change the value off each box automatic but how can I access the box in html/js?
#7 2017-10-12 07:50:12
You can select them by name.
p_j_j   (i= row, j = column)
#8 2017-10-12 20:55:27
Doug
Which library did you use?
#9 2017-10-13 13:22:22
Couple of lines of jquery
