updated version until 1653 stopped working. printer kld-lcd 1260 / restore the version back to work. and add the Russian version
[img = .png] http://www.nanodlp.com/forum/uploads/95 … 1a934d.png [/ img]
Andrel it is not clear by not working what you mean, everything on the screenshot looks normal. You start printer and it does not do anything?
I've had the same with this version.
Its a new install, for a second machine, so redid it again to make sure it wasn't my config.
It runs for around 5 minutes then hangs. if printing the display changes to the login screen.
Seems exacerbated when its slicing.
I downloaded the debug file so have it available.
If it hangs on after before the first layer, it is firmware and WaitForDoneMessage gcode issue.
Some additional feedback. My working ( original Pi ) was also upgraded to this version and seems to be working fine.
The one one that's not working install was done with the nanodlp image for the D7 and then upgraded to the latest stable version directly from the original image, so maybe a big jump in versions contributing.
Ive done a re-image and will run with the original install version and see if it works.
I re imaged the 2nd one with the original 1437 version and it works with that.
The only difference I can think of is that the working one had other versions in between.
Think I'm going to load the current download image and apply the json file on the site and see how that behaves.
I reloaded with the base Version 1437 and with that it works fine. is there a way not update to the latest version.
Sure you can keep continue using 1437
Looks like 1653 has been pulled? if I update the Pi will it now update to 1634?
yes agree with Redsalamander, when slicing it happens more frequently.
having similar issues. How can I get an older version?
Could you post your debug file, so I could fix what is wrong with current version?
