#1 2017-01-23 15:55:50
CERBERO
HOW TO SYNCRONIZE
Hi i'm new whith DLP printing and nanodlp. I have a wasp topdlp printer. top dlp
I have some trouble with the motion. what i need to do is: from the home position go into the resin jar to bring the resin, then lift up the plane in printing position and expose; then stop exposing, move the plate into the jar, lift the plate up again and expose.
can someone help me? thanks
#2 2017-03-02 21:06:13
jamesarm97
Re: HOW TO SYNCRONIZE
What firmware does it use? I had the same problem with the D7 using sprinter or something like that so I modified Repetier to support the nanodlp z_move_comp command then you can wait for those return responses before going to the next step or exposing a layer.
