I'm using build 1261, just submitted a part for slicing and some layers exhibited strange cuts in some edges. This happened in every profile I've created (different layer heights, with or without dimming) in a very consistent manner, across the same part regions. The same part sliced in printstudio didn't present the same defect.
I would like to attach the stl file and a slice example to better show what I mean, but don't find a way to attach documents here
any help is appreciated
thanks
This issue just present on the latest build?
I've been away from the machine, kust installed a new RPi and the most recent version, so I have no idea what could have been the behavior in earlier versions
Just found out how to add attachments, hope it works, just pointing out the sort of issue I'm observing. The top slice was done with Printstudio, the bottom one with nanoDLP, same layer height
best
I have found similar issue with our CNC slicer yesterday (same code base as nanodlp). When starts on exactly 0,0 point in some conditions it could get ignored.
You can try latest beta version. If it does not fix the issue for you, I will need the STL file to troubleshoot.
I've tried to slice the same object with build version 1280 and today with the beta (1296) and I keep obtaining a similar slicing error, some edges appear cut
I tried to upload the stl file, but I'm not allowed, can I email it to you?
Best
Sure email it to me
I have fixed the issue. Let me know if you see any similar issues.
