#1 2017-10-12 08:36:14
Yianni-VJ
Slicer error
My modeling program reports:
General information about this mesh:
  Mesh does not have any degenerate faces.
  Mesh does not have any extremely short edges.
  Mesh does not have any non manifold edges.
  Mesh does not have any naked edges.
  Mesh does not have any duplicate faces.
  Mesh does not have any faces with directions different from the mesh as a whole.
  Mesh does not have any self intersecting faces.
  Mesh does not have any disjoint pieces.
  Mesh does not have any unused vertices.
However, the nanoDLP slicer cannot detect all the contours correctly.
Luckily, nanoDLP supports SLC format.
Here are two images, first one of the sliced STL and second one of the SLC converted:
https://www.dropbox.com/s/lix05n5iplqkh … 9.png?dl=0
https://www.dropbox.com/s/l13qiqqrwkb9p … 9.png?dl=0
#2 2017-10-12 08:43:20
Yianni-VJ
Re: Slicer error
In a closer inspection, another STL in the plate does have minor issues, the kind that does not cause printing problems with other slicers
Modeling program reports:
This is a good mesh.
Important things to consider with this mesh:
  Mesh has 50 pairs of faces that intersect each other. Although this does not
    necessarily mean that the mesh is bad, it can cause problems if you're doing mesh boolean operations with it.
#3 2017-10-13 13:24:34
Re: Slicer error
Could you share the STL file?
#4 2017-10-13 19:19:41
Yianni-VJ
Re: Slicer error
Sure thing, I m emailing you the file.
#5 2017-10-13 23:50:26
Re: Slicer error
Please, try the latest version and let me know if the issue still persists.
#6 2017-10-14 11:39:33
Yianni-VJ
Re: Slicer error
I upgraded to Build 1687, resliced the same file, the error is gone !
Thank you very much !
In the future, I would like to stay on the stable release channel.
When I get a notification about a new release, is it going to be Stable or Beta?
#7 2017-10-14 21:17:27
Re: Slicer error
Stable
