#1 2016-12-20 10:22:11
jmbringenio
Projector bug: why I see my plates zoomed?
Hi everyone, sorry for my English. I have the new version of firmware: 1307. My projector ACER P1500 does not work properly cause my plates appear "zoomed" in the flexvat, I mean, if I want to print a 20x20 square I obtain a 50x50 square. I have checked the projector configuration 100 times! Does anyone suffer the same?
#2 2016-12-20 17:23:56
Re: Projector bug: why I see my plates zoomed?
nanoDLP does not have such feature so it is something to do with your projector (settings related or zoom ring related.
#3 2016-12-20 20:29:56
mandreas
By the way  have you  correctly set the xy resolution in relation to the distance from the platet, under "printer profiles?
#4 2016-12-23 14:49:06
jmbringenio
i've solved the problem. My config.txt archive was corrupted. reinstall nanodlp.img in a new SD and projector works good
#5 2017-12-29 16:32:41
Chris0812
Also had this issue - for me, it was enough to "Force" the Resolution in the config by Setting it to 1920x1080 instead of Auto-detect (or whatever it's called)
