#1 2017-04-23 21:39:29
mandreas
Setting nanodlp on KLD-2150
Hi Shahin,
I try to convert my KLD-2150 from photonic 3d to nanodl (the first love does not forget smile, everything seems to work and respond to commands (z axis, lcd panel)
The problem occurs when I launch a print: the z axis goes to G28, then it is all, no slice projection, everything ends here,
I attach debug files,  could you check where I am wrong,
thank you very much
https://www.dropbox.com/s/e80ruof0cettw … 6.zip?dl=0
#2 2017-04-25 04:43:10
Re: Setting nanodlp on KLD-2150
Something is wrong in gcodes. I suggest to take a look at D7 configurations.
http://3dprinterwiki.info/wiki/wanhao-d … ettings-2/
It is almost identical to KLD-2150
#3 2017-04-26 16:52:38
mandreas
In fact, I had installed nanodlp image for Wanhao d7, which uses FW Repetier (could be?.), now i  changed FW Marlin for Muve, all  function great , except the command M106, M107, the LED does not turn on, i think Is due to some configuration, related to Fansoft maybe??!!
#4 2017-04-26 23:28:52
mandreas
I solved the problem by using the FW of Sprinter master,
I think there is in Muve, some settings for the Fan (D9) that prevented M106
